Logging contacts in World Radio League is fast, flexible, and powerful — whether you’re just getting started in amateur radio or you’re an experienced operator looking for a modern logging solution. This guide walks you through how to create logbooks, enter QSOs, use helpful tools like CAT control and spotting, and explore maps and statistics.
Getting Started #
Log In #
Visit staging.worldradioleague.com and log in for free.
From your dashboard, you can:
  • Create a new logbook
  • Open the QSO Manager
  • View and edit your recent QSOs
Creating a New Logbook #
  1. Go to the Logbooks section
  2. Click “New Logbook”
  3. Name your logbook (e.g., “James’ Demo Log”)
  4. Choose a template:
    • Default WRL Logger (recommended for general use)
    • All Fields Logger (advanced data entry)
    • POTA Logger (for Parks on the Air)
  5. (Optional) Add an Activity if you’re activating a park, summit, etc.
  6. Set your Operating Location:
    • Choose from saved locations or set a custom one
    • Location data powers map generation and propagation statistics
  7. Click Save
Logging a Contact #
Inside the logging interface:
  1. Enter the Call Sign
  2. Use the Tab key to move through entry fields
  3. Enter details like:
    • Frequency
    • Band and Mode
    • Optional fields (time/date, grid, park number, notes)
  4. Press Enter to log the QSO
✅ Logged contacts appear instantly in your contact list below.
CAT Control Integration #
If you’re using CAT Control, WRL can automatically:
  • Read your current frequency from your radio
  • Update the logger in real-time when you change frequencies
  • Display S-meter readings
Learn more in How to Set Up CAT Control.
Using the Quick Settings Bar #
Located at the top of the logging interface, the Quick Settings Bar lets you:
  • Change your operating location
  • Switch your logbook template on the fly
  • Add equipment metadata for later analysis
  • Toggle between default WRL, POTA, and All Fields templates
Templates change which fields are visible in the logging form — for example, All Fields gives you access to more advanced data entry.
Advanced Entry Options #
Below the main form, you’ll find secondary fields for additional logging details:
  • Manual Time/Date: Log a QSO from a past day
  • Notes: e.g., “First contact with Antarctica”
  • Power level, SNR, RST
  • POTA Park Numbers (for hunting or activating)
  • Grid Square and QTH details
These allow for more complete entries and better export formatting for awards and activity platforms.
Spotting Integration #
World Radio League features a built-in spotting interface:
  • See active operators from sources like POTA
  • Filter by band, mode, or DX
  • View in table, grid, or map layout
  • Double-click a spot to auto-fill your logbook
You can also:
  • Spot Yourself using “Spot Me”
  • Spot the Other Operator using “Spot Them”
If you’re running a POTA activation, you can even auto-spot to POTA directly from the logger — no need to open POTA.app separately.
Mapping & Statistics #
After logging contacts:
  • View your QSOs plotted on an interactive map
  • Click Share Map to generate a downloadable summary image with:
    • Bands used
    • Modes used
    • DX entities worked
    • Total number of contacts
    • Rate statistics
These maps are great for sharing on social media or tracking your own progress.
Exporting, Templates, and Settings #
From the logging screen:
  • Click the gear icon (Settings) in the top right to:
    • Export ADIF or Cabrillo files
    • Adjust equipment details
    • Change other logbook preferences
You can also manage all of this from the Logbooks page where you can:
  • Delete a logbook
  • Import ADIF files
  • Rename or update logbook properties
Mobile Logging #
World Radio League is available as a mobile app (iOS) that syncs with your web account:
  • Log contacts in the field (even offline)
  • Use GPS-based location tools
  • Sync logs automatically when connected
Your mobile logs appear in your online dashboard instantly.
Support & Feedback #
If you encounter issues or want to request a feature:
  • Use the “Report a Bug” button in the app
  • Join the WRL Community Chat to connect with other operators and get help from the team
With World Radio League, you can log faster, track more data, and visualize your contacts like never before. Whether you’re operating from home, activating a park, or chasing DX, the platform gives you the tools to manage your logbooks with ease.
